Enable IPFIX Globally
IPFIX allows you to monitor IPv4 traffic flows. Use the following procedure to enable IPFIX globally.
The default global state is disabled.
- Select IPFIX.
- Select the Globals tab.
- To enable IPFIX, select enable in the ConfState option box.
- Optional: To configure an observation domain ID, type a value in the ObservationDomainID field.
- Optional: To configure the aging interval, type a value in the AgingInterval field.
- Select Apply.
Use the data in the following table to use the Globals tab.
Name |
Description |
ConfState |
Specifies whether IPFIX is enabled or disabled. The default is disabled. |
ObservationDomainID |
Specifies a value for the observation domain used to send IPFIX messages. The default is 0 (no observation domain). If the value is 0, data that is sent is not applied to a single observation domain. |
AgingInterval |
Specifies (in seconds) the flow record aging interval. The aging interval determines how long a traffic flow that is no longer being received is retained as a flow. The default is 40 seconds. |
